Southernspeed
I need some advice from those in the know!
I’ve just installed new axle bearings ( ‘51 8N), both sides and setting the preload.
I shimmed it right to the point where one axle stayed stationary when I turned the other ( it didn’t rotate in the same direction as the book suggests). It seemed so tight I didn’t want to go tighter to find the point where they both turned in the same direction. I then added shims until they turned in opposite directions but they are still ( seemingly) very tight to turn. I can only just turn them by hand ( holding onto bare axle shaft, no extra leverage from hub etc)
Does this sound right?
I realise that with a big diameter, heavy wheel on, they’ll turn easily but I don’t want to burn the bearings out. I’m used to taper roller bearings typically having some free play.
Your wisdom please!
Your wisdom please!
