8n problems
/ 8n problems #1
huntnfarm
8n Ford
Hey fellas just found out about this site and can't wait to get back home on the computer to look at all this information better. But I'm up here at farm(N missouri) and our 8n won't stay running. Battery and generator all tested fine. Went through all the wires to back sure no bare spots. If we jump it, runs anywhere from 2 minutes to hour or so. Any ideas???? Thanks in advance and look forward to reading this forum in the years to come
/ 8n problems #2
:welcome:
How does it shut down when it stops running?
Start to miss a lot at first, or lose power and stop, smoke a lot before stopping, stop like turning the key off? Or what? :)
Is the generator not charging the battery? Can you jump start it immediately after it shuts down or have to wait to charge the battery?
/ 8n problems
Shuts down like when you turn the key off. After it runs awhile it takes bout 10 to 15 to let it cool before it starts again and that's been normal since we got it. No smoke or anything. Battery still has juice.
/ 8n problems #4
at stall, check spark.. if it has spark.. it's a fuel issue ( which it DOES sound like ).
is this a front mount or side mount N.
6v I assume since you said genny.
post back and we can work you thru this.. you've come to the right place... 24/7 tractor tech support nights, weekends and holidays...good free advice and lots of nice people.
soundguy
/ 8n problems
Alright now its dark out. Was messin around with it pullin plugs wires re attaching them. After couple hours it started up. Ran for about 2 minutes and bam died!!!! Its a side mount. Have spark at plugs. I'm baffled with no where to go
/ 8n problems #6
if it won't start and you have good blue/white spark at the plugs, then look at fuel. ( orange / red spark won't cut it ).
first thing I'd do is get a glass jar and pull the plug on the bottom of the carb and watch the fuel drain. if it drips out or is empty.. you know there is a issue.. either at the tank tap.. or the flaot / valve.
post back.
soundguy
/ 8n problems
Will do sir. She's out in a field for the night but I will get back to you guys tmrw. Hopefully this will solve the problem. Appreciate the quick responses!!!! This old N has been good but since june she's been struggling. We first thought it was electrical and replaced pretty much everything electrical. Wish I woulda found this place months ago. My food plots have been on fritz with this problem
/ 8n problems #8
starts and stalls generally is a fuel issue. can be electrical.. but with a spark check it's easy to test.
soundguy
/ 8n problems #9
Run a 2oz per gallon mix of Sea Foam. It may or may not help the running but it sure will clean up the fuel system and remove the piston carbon.
Sounds like you may have trash gathering around where the fuel drains from the tank? i agree with the others it sounds fuel related at this point.
/ 8n problems #10
Hi Guys whats up ? Say i hope you all can help me with this my Case 480C 's got a Borg Warner Power Shuttle Transmission i overhauled it myself and changer to foward clutches. Now when i test it is pumping all the oil into the torque converter till it overflows while the sump reading shows empty ( oil not returning) Is this Air ? Do i need to purge system ? Thanks JON
/ 8n problems
Fuel drains out of carb good. I'm so lost at this point
/ 8n problems #12
Welcome BATCH. I think you will get a better response to your Case question if you open it as a new thread with "____Case____" in the topic box
so other Case owners will see it. Help will come.
/ 8n problems #13
Check the coil and dist. cap for a crack. Maybe the crack opens as things warms up and sparks to ground?
/ 8n problems #14
I'm old enough to remember the old "points & condenser" ignitions. Replace the condenser (and points also) I've seen vehicles with weak condensers run poorly or die when the condenser gets hot. When it cools off it will start again then run till it gets hot again. i think Tractor Supply stores keep these in stock.
Jack
/ 8n problems
points, distributor, coil, wires, plugs, voltage regulator, battery were all replaced within last 2 months. had to get back home so were having a guy come out and take a look at it this week. had to pull it back to farm with 4wheeler and got it back and messed with it. every so often it would fire but ran no longer than 15 seconds and die. started backfiring also. two weekends now I have been unable to disc for fall plots:mad:
/ 8n problems #16
you will likely get a better response if you start your very own thread with it's own title, instead of putting this at the end of a thread on a 50-60 year old unrelated tractor :)
soundguy
/ 8n problems #17
soundguy
Isn't this thread still about huntnfarm's 8N ?
(or did I miss a deleted post?)
/ 8n problems #18
Yes, this thread is about the 8N.
The Case 480C transmission question by Batch is the off-topic post that Soundguy and Nickel Plate were referring to.
Back to thread...
We used to have a 9N and 8N tractors. It does sound fuel related, but I would not rule out something remote like the "balast resistor" that is in the ignition circuit. It could be heating up and breaking down. These can often be replaced with the resistor from a Dodge if you cannot find one for the 8N.
/ 8n problems #19
And don't rule out getting a bad condenser. Buddy had a 600 that threw him many fits, until he replaced the "new" condenser with another new one.
/ 8n problems #20
you may want to check your fuel tank also. Ive seen alot of tractors shut down due to trash in the tank
iDrive TDS-2010H...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
159116 (A60430)
159116 (A60430)
Lucknow 360 Feed Wagon (A63118)
Lucknow 360 Feed...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
Kubota Skid Steer Pallet Forks (A64047)
Kubota Skid Steer...
