8N Prime is back! .. but another problem now
   / 8N Prime is back! .. but another problem now #1
cfb
Bronze Member
Cleveland, Ohio
1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
:laughing:
dear Soundguy, was I ever thrilled today. I ran some sae 80 through the relief bolt and started cranking. It did not start, but I knew it as pumping as oil was coming out of the tubes at both ends, at the gauge and at the other end of where that tube ends - I forgot to tighten them when I first checked to see if oil was squirting out. I also so some movement of the gauge needle, maybe 3-5 pounds. I had read someplace that you should see it but did not understand that till now. What is occurring internally when cranking it over that causes the pump to work? I guess I thought the engine had to be running.
I was really nervous when I started but got up the courage today. I'll start a new thread on getting the tractor started. thanks for your help on the oil issue - hope to hear from you on my starting issue. cfb
   / 8N Prime is back! .. but another problem now #2
well.. think about it.
when the engine runs, the pump spins.
when you are cranking hte engine you are using an electric motor ( starter ) to spin the engine.
the 'spinning engine' is the key.
yer oil pump is driven off the front main..
if you were superman enough, you could put her in neutral, engage the pto, and grab the pto shaft and spin her by hand and make oil pressure and spark.. ;)
soundguy
makes sense. thanks
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
