8N original engine deck height
   / 8N original engine deck height #1
Carrollton, OH
JD 318, Case 680C backhoe, JD 850 4wd, Cat D2 dozer, gravely L
Does anybody know what the original deck height is? We have one that has around .060 shoulder depth and the liners are about .030. We could deck the block but could run into piston/head clearance. Thanks
   / 8N original engine deck height #2
You could relieve the head by laying it on the deck sans gasket, and put a thin smear of grease on the pistons, and roll over and see where it prints.. Same with valves.
Die grinder and bur work.. He's is easy to cut, quite soft. Cut a lil then re check., rinse, repeat..
After you get it so that it is completely non interference plus a small safety margin with no gasket, then you should be good, hot, with gasket.
Thanks Soundguy, I think we have decided to bore the block, wipe out the shoulder bore and replace the .040 sleeves with .090 and re-cut the shoulders into the block. There will be machine work no matter what we do. Thanks for the help.
   / 8N original engine deck height #4
not uncommon to go to the CI sleeves
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2018 John Deere 460E Articulated Dump Truck (A53473)
2018 John Deere...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
