8n ford
   / 8n ford #1
clid
sterling hts. mi
8n ford
I have a 8n ford. When I last used it it was fine. I went to start it the other day and it will not turn over. I have checked the battery it is well charged. The thing does not seem to be getting any power to the starter. I have power from the battery to the solenoid. Ihave power to ignition switch. I do not seem to have power to headlights I do not even get a clicking noise from solenoid. does anybody have any ideas what it could be.
   / 8n ford #2
Check your ground cable, where it attaches to the chassis.
   / 8n ford
I have cleaned both cables with wire brush. I also cleaned and sanded the connection on chassis. the connection should be good.
   / 8n ford #4
Try by passing the starter button with they key on and in neutral touch jumper wire together or it could be the key ignition switch hot wire it I had a bad key ignition switch on my 8n! Good luck...
   / 8n ford #5
I can't recall the exact wiring from when I converted mine to 12V, but don't forget the neutral cutout switch on the tranny when you're checking things.
2008 INGERSOLL RAND DD-16 SMOOTH DBL DRUM ROLLER (A51242)
2008 INGERSOLL...
Pallet Fees (A50775)
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
Land Honor Quick Attach Accumulator Grapple (A50514)
Land Honor Quick...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
