8N distributor
   / 8N distributor #1
Varmint1
Deville,La
JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
What do I need to do to pull the distributor off to replace the points, condenser, do I need to bring it up on number one cylinder before I pull it off or can I pull it off where it sits. Thanks Patrick
   / 8N distributor #2
which 8n you got? if it is a front mount, you don't do anything special... you flip the bail down, let the square coil dangle by it's power wire.. pop the crab cap off and let them hang on spak plug wires. remove 2 bolts from dizzy and take to bench.. replace points.. put back on.
.. spin rotor with your finger as you hand tightenthe 2 bolts... the cam has an offset drive slot that will line up with the tang on the dizzy as you spin her.. once in.. take bolts down.. 15 miutes if you are slow. ps.. owners manual for a 9n/2n and the service manual on all N show the funny method to static time the front mount dizzy using a straight edge and the 1/4" measurement. tip.. if you do that.. a 1/4" drill bt stem is a good tool
if it's a side mount.. you don't remove anything but the cap and dist shield and just put points in leaning over right front tire...
post back if ya got any more questions.
remember.. front points gap at .015
side points gap at .025
spark plugs gap at .025
use a clean feeler
   / 8N distributor
I forgot to tell y'all it was a front mount, thanks Soundguy for the info
   / 8N distributor #4
post back if you hit a snag
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
40ft Sea Container (A52384)
40ft Sea Container...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
