Ballast 8n coil locations
   / 8n coil locations #1
maizeandblue
pensacola, fl
2006 Mahindra 3525 w/ FEL
My father in law bought a used head for his 1950 8n to replace the head on his tractor. His head has been repaired a couple of times and now has a new leak. The existing head has the coil mounted in front with a tapped hole on the side and front of the head. The new head does not have these holes to accommodate the coil. Is there another location the coil can be located? If so can someone post a picture so we can see where or how to relocate the coil.
Second, the new head on the left side has the oil filter bracket holes, but also has what looks like a 9/16 or a 5/8 plug right behind those oil filter bracket mounting holes.
Besides these two differences are the two heads created equal/same?
   / 8n coil locations #2
He needs the correct head. He apparently got a head from a '51 or '52 tractor with the side mounted distributor.
   / 8n coil locations
As I Understsnd It, In 50 They Made Front Mount And Side Mount Dist. His existing Distributor Is Mounted On The Side. IT Is The Coil That Is Mounted In The Front. Other Than The Coil Mounting Holes And Oil Filter Bracket Holes Are The heads Basically The Same?
SOrry About The Caps, Dern Phone.
NEW Landhonor Diamond Dry Drill Set (A59000)
NEW Landhonor...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
Mini Skid-Steer 60in Straight Digging Arm (New/Unused) (A59225)
Mini Skid-Steer...
