Ballast 8n coil locations
   / 8n coil locations #1
maizeandblue
pensacola, fl
2006 Mahindra 3525 w/ FEL
My father in law bought a used head for his 1950 8n to replace the head on his tractor. His head has been repaired a couple of times and now has a new leak. The existing head has the coil mounted in front with a tapped hole on the side and front of the head. The new head does not have these holes to accommodate the coil. Is there another location the coil can be located? If so can someone post a picture so we can see where or how to relocate the coil.
Second, the new head on the left side has the oil filter bracket holes, but also has what looks like a 9/16 or a 5/8 plug right behind those oil filter bracket mounting holes.
Besides these two differences are the two heads created equal/same?
   / 8n coil locations #2
He needs the correct head. He apparently got a head from a '51 or '52 tractor with the side mounted distributor.
   / 8n coil locations
As I Understsnd It, In 50 They Made Front Mount And Side Mount Dist. His existing Distributor Is Mounted On The Side. IT Is The Coil That Is Mounted In The Front. Other Than The Coil Mounting Holes And Oil Filter Bracket Holes Are The heads Basically The Same?
SOrry About The Caps, Dern Phone.
2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
2021 CATERPILLAR...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
toro turf sweeper (A50324)
toro turf sweeper...
International 475 14 ft Disc Harrow (A52128)
International 475...
