chh
Veteran Member
Hey AKfish, is there any way that you can post a pic of that tractor? I can't say that I have ever seen anything like that track setup. Good luck with the tractor and FIL.
chh said:Hey AKfish, is there any way that you can post a pic of that tractor? I can't say that I have ever seen anything like that track setup. Good luck with the tractor and FIL.
simonmeridew said:Hi AK
You post a question that many have wrestled with including to an extent myself years ago. What ends up prolonging the agony of decision of what to do is that these old tractors refuse to die, they're just so over engineered and rugged that you end up with a lot of little aggravations that could be fixed or made right but the tractor finally starts each morning so you put off doing anything to bring it up to specs.
However you might find it to be quite a rewarding experience rebuilding the engine yourself. The parts are absolutely available and really not expensive because of numerous enthusiast groups. There is nothing on the tractor that can't be taken off or undone with about four socket wrenches and the same number of open ends. Get one of the I & T books and you're all set. There is a series of VHS tapes that a family sells that shows in one videotape how to take apart and rebuild and put back together an N motor start to finish.
You need to understand, when these tractors were new, THEY RAN LIKE NEW. They didn't struggle to start, they didn't stall in the field, you name it they did it well. And better yet, you can easily rebuild them to do it again. The distributors distributed, the starter started, the generators generated. and the transmissions transmitted. They all can do it again. Your motor can do it itself with a little help. Don't buy someone else's motor, rebuild yours.
As an aside, the big upgrade of the 8N over the 2N/9N is the 4 speed transmission in the 8N. So putting an 8N motor in a 9N or 2N doesn't make it an 8N, and I don't just mean to the collector or purist owner: rebuild the motor you have, the tractor will work great and your father in law and you will end up with a neat tool.
sorry about the peptalk
simonmeridew
simonmeridew
