8N 302 V8 Awesone Henry Flywheel/Ringgear problem question
   / 8N 302 V8 Awesone Henry Flywheel/Ringgear problem question #1
wploetz
Dunkirk
Mahindra 60HST 60HP Diesel Compact 4WD Hydrostatic with factory cab, A/C, radio
Working on an 8N Awesome Henry 302 V8 conversion. Still have not got the motor running. Plan was to start it today but we ran into what we think might be a ringgear problem even though Don at Awesome Henry says this has never caused a problem and all his flywheels are built this way.
Starter howls - the awesome henry ringgear has the almost square cut towards the starter drive gear.
Shouldn't the beveled side of the ringgear face the starter drive gear?
Could that be the source of the howl?
This happens whether the motor is bolted to the tranny or not so the eliminates the pilot bearing.
Happens with old and new starter. Starters run quiet off the tractor.
No bolts are hitting anything and motor turns freely by hand with the plugs pulled.
Anyone have any thoughts or comments?
We are getting a new ringgear and will install it in what we call the correct way and see if that makes a difference.
Problem Solved!!!
I have the 164 tooth manual flywheel with the auto old style starter and I just figured out the problem. The kit included a 3/8" spacer to use the auto starter on the manual flywheel. Turns out I needed a 5/8" spacer. I tested my theory with a couple of washers and the howling went away. The inside of the bendix was touching the front of the flywheel when it spun out in the active mode. Nothing that 6 hours of debugging, disassembly, reassembly, repeat 5 times couldn't solve.
Turns out the cut of the ringgear teeth was not the issue.
   / 8N 302 V8 Awesone Henry Flywheel/Ringgear problem question #3
Good that you found the problem.. Sounds like a neat project..
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
UNUSED FUTURE FT 72 PRO 72" HYD MULCHER (A57193)
UNUSED FUTURE FT...
Year: 2012 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 154,716 Plate: Body Type: 3 Door (A56858)
Year: 2012 Make...
TANK MANIFOLD (A55745)
(3) 6' X 4' EXPANDED METAL (A57192)
(3) 6' X 4'...
