Backhoe 8a vs 8b backhoe whats the diff?
   / 8a vs 8b backhoe whats the diff? #11
Grizz -- Thanks. Great photos.
Looks like the swing cylinders on the 8B are a solid, chrome shaft. The 8A has large chain links extending from the hydraulic cylinder that forces the boom to the left and right.
From your pics, the basic layout looks like -- for the most part -- identical from the 8A to the 8B.
My owner's manual lists the specs for the 8A as;
Boom lift ability -- 400 lbs.
Bucket roll force -- 3,200 lbs. (estimated)
Bucket pry-out force -- in excess of 6,000 lbs.
Operating weight -- less subframe mount and bucket -- 950 lbs.
18in. bucket weight -- 94 lbs.
Digging depth -- 8 ft. 6 in.
Loading height -- 6 ft. 10 in.
Reach for Center line of Swing pivot -- 11 ft. 1 in.
There are other specs, but they're not all that sexy; i.e. stabilizer spread, ground clearance etc.
AKfish
   / 8a vs 8b backhoe whats the diff? #12
I took some of my own advice --- and went snooping around on a web site that listed the eqipment specs in a *.pdf format. The deere site for governmental purchases. Here it is and it lists quite a bit of JD equipment.
ttp://www.deere.com/en_US/govsales/purchaseguide/2006PG/links/30_31.pdf
This one lists the specifications for the JD7 and JD8B backhoes.
If you want to review some of the technical specifications for various JD equipment (utility-landscape) go here ---
Go here and click on the purchasing guide. A single page *.pdf file will load up. Click on the individual attachment reference and page number within that page. That will bring up the *.pdf specs for the particular attachment.
Enjoy
AKfish
   / 8a vs 8b backhoe whats the diff? #13
frankr990 said:
im looking at a used 8a hoe for my 990 tractor. whats the diff and if anyone knows about the mounting brackets that would be very helpful, its on a 1070 tractor now so would these brackets work to my 990?
I have an 8b hoe on order for my 970 but am researching a thumb for it. I am looking for the width of the arm where the base of the thumb would attach, can somone give me that dimension as I can not find it anywhere on the internet?
2003 Big Tex 10PI...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2012 International Prostar (A56435)
2012 International...
