88 Ford 555B Dump Valve Micro Switch Wiring?
   / 88 Ford 555B Dump Valve Micro Switch Wiring? #1
Johnny Glenn
88 Ford 555B
Thanks for looking in - Recently purchased 88 Ford 555B and the trans dump valve wasn't working. Turned out the micro switch was broken and no wiring. I got a new switch but don't know what wire and where to go? I've heard one wire to fuse / which one? One wire to trans solenoid / heard LH side of trans but nothing there? Do see possible spot on top of trans - two posts with no wiring. I don't need to wire to loader handle so the switch says "common", "norm open", "norm closed" -- how should I wire this switch? Gauge wire? I do see on the schematic, it looks as if the Horn & RTD is the fuse location - what does RTD stand for? Thanks!
That original post seemed a bit long! I'm trying to find out what wire goes where for the floor/micro switch to trans solenoid valve? Any help is greatly appreciated!
I guess this info is easily known on this old of a machine? I think I have the wiring figured out - Does anyone know where the trans solenoid is located?
   / 88 Ford 555B Dump Valve Micro Switch Wiring? #4
I put this diagram in one of your other posts, here it is again.
#2 is the solenoid, it's mounted on the left side of the transmission. If you could see through the battery box and frame, there it is.
Thanks - you've got me on the right track again! I hadn't seen the solenoid on the LH side the first time so I thought it must have been (something?) that I saw on top of trans beside gear shift. Anyhow I found it now on the side/bottom corner and I'm tracing and labeling wires etc - I guess #30 is the wiring harness - do you have any diagrams of that? Also is there way to diagnose if the solenoid is good besides hooking everything up and trying it out? Thanks again for your help!!
1267 (A50490)
1267 (A50490)
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2012 Dodge Ram 5500 (A52377)
2012 Dodge Ram...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
