870 with stuck clutch?
   / 870 with stuck clutch? #11
I'm having the same issue with my 870 I got in 1995. When it is on it will not go into gear, off it will. I looked in the inspection hole while someone was pushing on the clutch and I can see the plate moves away, it does not seem stuck. At least what I can see. I was able to rotate the whole assembly some. I didn't go all the way around.
I was able to push it into gear (it's hard to do), the tractor will move and when I push on the clutch it keeps going, won't disengage. Hit the bakes while pushing on the cltcuh and it wants to bogged down. Very strange. Any ideas?
I can see the PTO one and it's really close together, I can spin it when the clutch is pushed all the way down.
Thanks for the photos, I was looking under the tractor at first.:unsure:
EDIT: I found that the 2 plates were together, it was hard to see. The dealer said to spray some WD40 on it and it worked. Works fine now.
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
(2) BOXES OF MISC FILTERS (A58374)
(2) BOXES OF MISC...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
