87 JD 318 Starter won't engage - Onan B218G
   / 87 JD 318 Starter won't engage - Onan B218G #1
fjsaichjr318
Grantville, PA
1987 John Deere 318
Need some help fellows. Read some of the older posts in this forum with individuals who were having the same issues. Followed there leads and still have had no success. First time in 29 years have had any problem like this.
At this point here is what I have done:
New battery - May 2016 - shows 13.2 volts
New starter - New - replaced now
New key/ignition switch - New - replaced now
New Neutral start safety switch - New - installed now
Starter relay kit - New - installed now
Starter Circuit Breaker - New - replaced now
I am at a loss.
Looking for additional suggestions as to what could be causing problem.
Thank you in advance for you assistance.
   / 87 JD 318 Starter won't engage - Onan B218G #2
Are you saying the starter spins but does not engage?
   / 87 JD 318 Starter won't engage - Onan B218G #3
Wow, you threw a lot of parts at it. If you mean the starter will do nothing when turning the key, it is probably a safety switch that is causing that to happen. Post back with a better description of the symptoms and you will get better advise.
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
Ford Tractor (A50120)
7022 (A50322)
7022 (A50322)
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
