864G bucks going forward
/ 864G bucks going forward #1
elgman
Placerville, CA
bobcat 864G
My 864G started bucking when going forward, do I need to change the hydro fluid or did I use the wrong kind?
/ 864G bucks going forward #2
Bucking can be caused by a number of things. Worn out shock absorber(s) on steering linkage, Loose or worn parts in steering linkage itself, drive motor(s) outer bearing starting to fail, possibly brakes not releasing completely.
Start with the steering system this is most common cause due to normal wear.
/ 864G bucks going forward #3
I have a T200, which is your machine with different decals. My machine also bucks when moving, especially with higher RPMs.
I think a lot of it is operator technique. I find that if I back down a few hundred RPM, and move the sticks very carefully, the jerking is less. I've read that wear in the Bobtach can cause bucking, and that could be a possibility. I know that my wedges are worn, and I presume the thinking is that the bucket or attachment can "catch" and release rapidly and cause bucking.
New/Unused 5ft Quick Attach Mixer (A61166)
New/Unused 5ft...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2016 Isuzu NRR 18ft. Flatbed Truck (A61568)
2016 Isuzu NRR...
2018 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
Brent 420 Grain Cart (A63118)
Brent 420 Grain...
