863 Bobcat Idling wipe open
   / 863 Bobcat Idling wipe open #1
ThomasE
Maple lake, MN
bobcat 863
I have an 863 bobcat. When I start it up it idles wide open...even more than if the throttle were all the way open. I've heard everything from air intake, bad governor or stuck, bad throttle linkage etc. Can anyone point me in the right direction?
   / 863 Bobcat Idling wipe open #2
Welcome from Oklahoma. Not familiar with your machine, but yes, all those can cause that condition. The process of elimination is what you need to do. Check one thing, eliminate it as causing the problem, then go to the next item, and so on until you come to the cause of the problem.
Ken
   / 863 Bobcat Idling wipe open #3
Only a suggestion? Post your inquiry in the specific "Bobcat Construction Equipment" forum here on TBN. Your chance of receiving assistance will improve by doing this. BTW, Welcome aboard. Best wishes.
   / 863 Bobcat Idling wipe open #4
Welcome to TBN :)
I moved your thread to the Bobcat Construction Equipment Forum.
   / 863 Bobcat Idling wipe open #5
The couple of time I have run inot that this on the Duetz engine, it was the governor assembly in the timing case blew apart.
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
2011 Chevrolet Suburban SUV (A51694)
2011 Chevrolet...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
