855 secondary air filter install
   / 855 secondary air filter install #1
skiier
Freeport,Pa.
John Deere compact 855
I took my 855 deere apart today. I was going to install both the primary and secondary air filters. I struggled with this project for an hour. I gave up and installed only the large primary air filter. It went right in. With the secondary installed the outside cover would not seat. Any ideas??? Thank you Tom
   / 855 secondary air filter install #2
The air filters have a close tolerance fit that makes it sometimes tricky to get them seated all the way in. Only a guess here but that is probably the reason why the plastic cover won't snap lock.
   / 855 secondary air filter install #3
Did you compare the new filters with the old ones?
I only ask as sometimes we can all overlook the obvious. Done it many times myself.
   / 855 secondary air filter install #4
I believe there are two different filter arrangements. One uses a secondary filter and one doesn't. I would check the John Deere online parts catalogue or go to your local JD parts dealer. I think the large main filter is a slightly different length for each of the systems. If you use the wrong one, it may be possible to install a filter which will not seal and would allow unfiltered air into your engine. That would be a very bad thing!
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
CUSHMAN SHUTTLE GOLF CART (A51406)
CUSHMAN SHUTTLE...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2019 FORD F-250 XL SUPER DUTY SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
