855 60" deck
   / 855 60" deck #11
I'm used to the deck shut off, I'm still not used to the neutral shutoff these 2520's have. If you don't put it in neutral it will die when you jump off. My 855 didn't do that.
it's things such as this that have me hesitant to buy a newer tractor. The best safety mechanism rides between your ears, not some switch on the tractor.
   / 855 60" deck
About $50 each for the sheaves. Think you can beat that?
I was trying to look them up online but there seems to be a multitude of different numbers. I'll have to see if the serial # is still there and see what I actually would need. I do bodywork for a living and was figuring on having a local place sandblast the deck then epoxy it. That's if I don't need a fortune in parts. I just saw a post what a gearbox is listed on ebay for. So whatever I do, I feel OK about buying it.
   / 855 60" deck #13
I don't know about your machine but I have a 650, also a JD/Yanmar machine. Deck parts seems to be hard for JD to look up for some reason, have the serial number of the deck handy...that will help. Also you talked about some pulley needing to be replaced....again I don't know on your machine but mine has a mule drive that has some bearings that you will need to look at, but if the actual spindles are what is bad hold on to your wallet...they are a couple hundred a pop at JD.
   / 855 60" deck
The spindles themselves are fine. The pulleys are ruined from rust. Apparently grass laid in the valley and it must have set out in the weather.
202480 (A54757)
202480 (A54757)
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2016 John Deere 35G (A55272)
2016 John Deere...
