850D XUV starter mystery solved
   / 850D XUV starter mystery solved #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
After a day's work on the trails, I stopped in front of the shed and turned off the engine before putting the gator away. Came back later to drive it into the shed and it wouldn't start. Had panel lights, box would lift, key just made a click sound.
I discovered that I ran over a tree branch, which got up between the cab and the box and into the engine compartment. Carefully removed the branch and saw that it had pulled a wire off the starter. It was one of those "clip on" tab connectors.
Hard to believe that stick could find it's way to that exact spot! (Even harder to believe I noticed the wire).
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
