850D XUV starter mystery solved
   / 850D XUV starter mystery solved #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
After a day's work on the trails, I stopped in front of the shed and turned off the engine before putting the gator away. Came back later to drive it into the shed and it wouldn't start. Had panel lights, box would lift, key just made a click sound.
I discovered that I ran over a tree branch, which got up between the cab and the box and into the engine compartment. Carefully removed the branch and saw that it had pulled a wire off the starter. It was one of those "clip on" tab connectors.
Hard to believe that stick could find it's way to that exact spot! (Even harder to believe I noticed the wire).
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
BUSH HOG 7007 LOT NUMBER 111 (A53084)
BUSH HOG 7007 LOT...
More info coming soon! (A50322)
More info coming...
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51246)
2014 TAKEUCHI...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2021 Vermeer Wood Chipper (A51573)
2021 Vermeer Wood...
