850D case dozer transmission trouble
   / 850D case dozer transmission trouble #1
gettindirty
MC,SC
850d case
I have a 1996 850D Case Dozer that was recently serviced by a "certified technician." Problems with the dozer is it would go in reverse but it wouldn't pull. The "technician" has pulled the dozer apart and it still isn't fixed.. Any suggestions on what to check would be appreciated. Here's what has been done so far....he took the reverse clutch out, replaced the ring that holds the clutch pack. The clutch pack housing was busted. He replaced the housing. Now you can switch the dozer in reverse and it won't pull, then when you press the gas pedal it won't move into reverse. You can let off the gas and then press the pedal and then it will go, still seems very weak. It will go into forward and pull in forward when using the levers and turn in forward with no problem. The problem is isolated to reversing. My thoughts are the problems are in the valve body. Does anybody have any info on how to run a pressure test on this model dozer or any suggestions on what to try next?
   / 850D case dozer transmission trouble #2
You might post your question on heavyequipmentforums.com
There are a lot of knowledgeable guys over there that know heavy equipment.
   / 850D case dozer transmission trouble #3
i realize this post is old, but did you ever get an answer?
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
ExMark Vantage 48in Stand-On Commercial Mower (A59228)
ExMark Vantage...
WHIRLPOOL REFRIGERATOR/FREEZER W/ICEMAKER (A60432)
WHIRLPOOL...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
