850 ignition problems
   / 850 ignition problems #1
Steve Mort
ford 1955 850
My problem happened when the coil blew up on my 850. I replaced the coil and it hasn't run since. Voltage is to everything, (converted to 12 volts) points open and close. I'm going to replace the points and condenser, but I have been looking all over for the copper strip and the insulator for the in and out side of the distributor. anybody know a good on line parts store.
   / 850 ignition problems #2
just make one. I've made so many of those copper strips from pounding some copper line flat that I'll never have to make another one.. And as far as the insulator.. be creative.. license plate nylon expansion grommet.. um.. rubber cort with a hole drileld in it.. wire from the outgoing primary of the coil run straight into the dizzy thru the hole to the points and a glop of rtv.. etc.
if you have power on both sides of the coil primary.. you are not getting the points to close.. or there is an open circuit.
soundguy
2017 Ford F750 Buck Truck (A52377)
2017 Ford F750...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
