841 Ford diesel Brake issues
   / 841 Ford diesel Brake issues #1
Willy Stripit
841 powermaster
This is my first tractor. The right pedal hall way down at rest. Jacked up and adjusted both brakes. Left brake perfect right brake did not rase and sounds like gears grinding when I step on it. Preparing to replace shoes and hardware on right side but have no idea what makes the gear grinding sound. Anything else I could should be prepared to fix while I have it apart?
   / 841 Ford diesel Brake issues #2
Does the sound change depending on the speed you are driving the tractor? Does it make noise when not moving? Does that brake work, or does it just make noise?
I only stepped on th right one once it sounded so harmful didn’t try it again I really didn’t give it a chance to stop the tractor. At a slow speed had a little noise on left side that goes away at higher speed
   / 841 Ford diesel Brake issues #4
Sound's like classic "metal on metal" after bands are worn out. Tonight's trivia question for the TBN crowd. Why the right and not the left?
   / 841 Ford diesel Brake issues #5
Farmer liked to make right hand turns at the end of the field.
   / 841 Ford diesel Brake issues #6
Brakes can make a lot of noise. Pull it apart and the source of the noise will likely be obvious.
Thanks I’ll pull it apart and take a look
John Deere 648G2 Grapple Skidder (A52384)
John Deere 648G2...
2025 Mower King SSRC (A50123)
2025 Mower King...
2024 JOHN DEERE 461M LOT IDENTIFIER 142 (A53084)
2024 JOHN DEERE...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2010 Cadillac CTS Sedan (A51694)
2010 Cadillac CTS...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A53426)
2010 PETERBILT 387...
