820 3 cyl. clutch
   / 820 3 cyl. clutch #1
cannedman
Kentucky
John Deere 820
Does anyone have any suggestions on where to order clutches for the 820 3 cyl tractor other than John Deere?
TIA
   / 820 3 cyl. clutch #2
I took mine to a shop and had it and the pressure plate rebuilt. Might look around in your area and see if there is a shop that can rebuild them. The shop I used is in Springfield MO, which is about 100mi from me.
   / 820 3 cyl. clutch
I will check and see it there is one around here.
Thanks and have a great day.
   / 820 3 cyl. clutch #4
You might ask at your NAPA dealer they may be able to get the replacement parts or may recommend someone to resurface your clutch.
Have you determined for sure that this is a problem?
   / 820 3 cyl. clutch
The transmission clutch is down to the rivets and the pto clutch has about 1/8 inch left on it.
   / 820 3 cyl. clutch #6
When I put a clutch in my JD 2030 the dealer said he alternate sources if I did not want to go with JD parts. Might want to check with the dealer.
   / 820 3 cyl. clutch
I found a company that will resurface and rebuild everything including the throw out bearing and preasure plates for $350.00.
   / 820 3 cyl. clutch #8
For $350 you should jump on it.:D:thumbsup:
   / 820 3 cyl. clutch
Yes I going to.
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
