buickanddeere
Super Member
Why would you install the wrong oil with the incorrect additive packages ? Sae gear oil is not wet clutch and wet brake compatible. GL-5 will attack clutch and brake fibers. If any moisture enters the system GL-5 will also attack copper allow components.
Do you know how much repairs cost ?
You could fill it with diesel fuel and it would operate for a while. Just because it "works" doesn't make it right.
