8050 Branson Tractor 3 point lift will not go.
   / 8050 Branson Tractor 3 point lift will not go. #1
travlitt
Platinum Member
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
Was preparing to sharpen the blades on my Titan 8' mower. Tractor had been left overnight in my shop. I started the tractor to raise the deck with the 3 point but it will not even try to come up. Hydraulic oil is at the proper level and the electric fuse is good. No codes. I removed the mower, still doesn't work. Need help, what do I need to check?
   / 8050 Branson Tractor 3 point lift will not go. #2
Check that one of the other valves is not stuck open. That will run all the flow through the relief, bypassing the 3pt.
   / 8050 Branson Tractor 3 point lift will not go. #3
Have you checked your fuses?
Once in a while mine will act strange,
moving the position control thru it's full range usually gets it going.
Also have you tried the one touch buttons or the outside control on the fender.
Also your draft control knob and speed control knob under the little flip up cover,
cycle those and try with them in the mid range.
Thank you ericm979 for the pointer.
You are correct. One of my rear remote valve control lever was in the indent position. This caused it to "bypass" thus causing the 3 point to not have an oil supply, not work. Corrected that and all is well. Many thanks.
   / 8050 Branson Tractor 3 point lift will not go. #5
Glad it was an easy fix.
Suzuki Kingquad ATV (A51694)
Suzuki Kingquad...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
