Oil & Fuel 80 weight oil instead of UDT? do you use it?
   / 80 weight oil instead of UDT? do you use it? #1
Randybee1
Hey guys, new guy here, not new to tractors just new to Kabota's and diesels. Anyway, I've read all the info on using UDT or its generic (134) but I'm wondering why on my tractor, near the fill hole for the trans fluid it calls out 80 weight oil. It also says in the manual I can use either. So... how many of you use 80 weight instead of UDT? and why? Thanks, Randy B in northeastern Maryland
   / 80 weight oil instead of UDT? do you use it? #2
I can't realy help with your problem as I don't know what model you have. Years ago they did use gear oil in the gear drives. The hydro's won't use it.
Art... Stupid me, I thought I mentioned the model #, anyway I have a B7100 built in 1985. It is not a hydrstatic. I suspect that prior to the HST models coming out, they all used gear oil.
   / 80 weight oil instead of UDT? do you use it? #4
My L3400 manual lists either. I have never checked to see what is in it. I had the dealer do the 50 hour but I'll do the rest of them. The front axle calls for 400 hour change.
My JD came with 80 in the front axle. That is the only oil listed in the manual for the JD.
I'm thinking in my climate I'd use the 80. If I lived where it got real cold I'd use UDT.
   / 80 weight oil instead of UDT? do you use it? #5
I'd think you would still want UDT, as the hydraulic pump draws from the transmission case. 80wt just sounds awful heavy to me.
   / 80 weight oil instead of UDT? do you use it? #6
I was thinking front axle here. The transmission should probably be UDT.
   / 80 weight oil instead of UDT? do you use it? #7
I stressed over it a long time on my L3400 and just ended up putting SUDT in it.
No worries as far as I'm concerned..
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
