8" Woodmaxx chipper arrived
/ 8" Woodmaxx chipper arrived #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I recently ordered a WoodMaxx 8" hydro feed chipper and it arrived Monday. It should have taken longer based on their website but it showed up in a week so their shipping speed is excellent.
When I unloaded it I noticed it was well packed and nothing was missing. I did noticed they added an RPM gauge and a PTO safety shield that attaches to the chipper both of which are a nice addition. My 15 year old son and I put it together after dinner and it took about 3.5 hrs from the unloading to ready to run. We took our time, checked all the bolts, greased everything and looked it all over. I can say it is very well made, welds seems good and everything was powder coated. I did have a few small spots that got scratched in shipping but it was not due to Woodmaxx not wrapping it well. it was very well wrapped in plastic and protected. Seeing it is a chipper I am not concerned about a mark and nothing was bent up or damaged at all.
I do recommend having a second person there to help assemble the feeder shoot as it is heavy and takes a little bit of pushing and pulling to get everything lined up perfectly. Easy with the help of my son but by myself would have been difficult.
Tonight I finally had a break in the weather and got to try it out. Started with a few smaller 1-2" limbs - chipped them right up without any hesitation. Next we grabbed a tree that died (Maple) - not huge but about 30' long and 5" at the base. We slid it up into the chipper and in it went - chips flew about 20' out and in no time it was gone. No fuss, no issues at all, heck the tractor didn't even seem to notice it was chipping (running it on MX5100 Kubota).
We chipped some other limbs and trees with branching going every direction and it simply fed them in and chipped them. Worked great! I don't have much time on the unit but so far I am VERY impressed with the machine and the hydro feed is well worth it. I have owned a "major" brands 4" self feeding chipper and it was a nice unit but the hydro feed is WAY better. No pushing, twisting and bending stuff, just load and walk away to grab the next branch!
The one thing I noticed when I was chipping is I need my chain saw/oil/gas so I can cut some other trees and get them cleaned up. Off to the shop we went for a quick addition. Here is what we came up with. Nothing fancy, just used some left over wood from the archery target holder I build for my son. I mounted it with one "L" bracket that uses an existing bolt on the chipper and the pin that holds the top link attachment point on. It comes off with one screw and pulling the hitch pin. Could be easily taken off in 1 minute. Nothing fancy but keeps the items I need close at hand and will hold either of my chainsaws. Seems like something Woodmaxx may want to make out of metal and offer as an accessory.
/ 8" Woodmaxx chipper arrived #3
I had the WM 8M and just recently sold it as I was done with everything I needed to chip. Great machine.
Used it for several hrs tonight and it did a great job! Love the hydro feed!
/ 8" Woodmaxx chipper arrived #5
Hey Code54, I really like your saw box idea and wished I had thought of something so simple when I got mine.
Would you make it any different now that you have used it? Where did you put the L bracket? I thought I just might secure mine in the middle like you did at the pin, but also up the back side where the " lift pin" goes. Whatcha think?
Thanks and enjoy your machine
/ 8" Woodmaxx chipper arrived #6
Just ordered a Red Woodmaxx WM8M. Have two large brush piles to chip. Can't wait.
Bill
Hope this helps some - basically I pulled one of the bolts that hold the housing together and just made a quick "L bracket" up and ran that main housing bolt through the L to hold it in place than ran a single wood screw through the top of the "L" and into the bottom of the rack. Figured if I needed to remove it I could just take that single screw out then pull the pin and it is off.
I would like to make up a nice tray out of ⅛" plate, power coat it and put a nice rubber mat in the bottom of it. Figure on the bottom I can still use the "L" bracket but instead of using a screw I can weld a treaded post on the bottom of the rack that will drop through the top of the L bracket (where the screw is currently) and then have a nice threaded knob to screw on and hold it in place. Thinking I will do that this winter when I have more free time and want a little project.
If you need anything please feel free to PM or respond to this thread.
Sorry - as for the design, so far it is working really well. Holds either of my saw, a small 1 gallon mixed gas can, the bar/chain oil bottle, pair of gloves and I can toss the files in the little area where the saws sit and they don't seem to move (drove about ½ mile one way the other day and nothing really shifted around)
May add a hook for my helmet so I can hang it when taking a break (One of those Stihl ones with the face should, hard hat and ear muffs built in - works great for chipper use)
/ 8" Woodmaxx chipper arrived #9
Cool. Thanks again. Like your idea a lot. gonna do 'er when I get a chance
Your welcome and thanks!
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
2017 TAKEUCHI TL8 SKID STEER (A65056)
2017 TAKEUCHI TL8...
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
