8 sweepster too big
/ 8 sweepster too big #1
russG
NH TC34
Hi, I have a TC 34 and am looking at a 8 foot sweepster. I'm wandering if its to big to use. The weight of the brrom is around 1000 lbs. My three point can lift
1635 lbs so i dont think this would be an issue. I'm not sure how much hp is needed to turn the broom. Can anyone give me any clues if this would work or not.
Thanks
Russ
/ 8 sweepster too big #2
My experience would be to recommend a 6-ft. Sweepster three-point broom. You will pick up an 8-ft. OK, but when you put the broom on the ground to sweep the angle of the broom will put a lot of side load on your tractor. In short, an 8-ft. broom will push your tractor around too much.
John Deere 3025E (A64126)
John Deere 3025E...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
