8 Foot Caroni Finishing Mower Dissapointment......
   / 8 Foot Caroni Finishing Mower Dissapointment......
Thinking the same thing. My ZTR manual states not to wash down the deck but to use a blower to clean off debris.
Could moisture build up under the covers?
Anything is possible but as I stated above there are 1/2 inch lips welded to the deck that the covers fit over and bolted down. See picture below. Also, these are sealed bearings and sit 3 inches above the deck with the covers over them. One would have to completely sink the mower in water a foot deep to get water to the bearings and they are the sealed type.
Since I installed the new bearings and belts last weekend I have loosened the bolt type adjustment on the belts as far as it will go so I know the belts are not too tight. A mower this large should have spring loaded idler pulleys but it only has a static type adjustment. Will also sparingly add grease past the seals before I use it next time and see what happens in the long run......
   / 8 Foot Caroni Finishing Mower Dissapointment...... #42
Really, they don't have spring on the tension adjustment linkage? Totally agree that is, well wrong.
Nope, At least not on the 8 foot unit. What is odd is that the 8 foot Caroni flail mower the idler pulley is spring loaded with much smaller belts. The 8 foot finishing mower has 5 blades and two 119” belts.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53472)
2012 KINZE FLAT...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2021 Ford F550 XL 4x4 Service Truck (A52384)
2021 Ford F550 XL...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
BESTWAY AG LOT IDENTIFIER 51 (A53084)
BESTWAY AG LOT...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
