7XXX Series Starter Problem - Again
   / 7XXX Series Starter Problem - Again #11
Wow, Duke you must be an Engineer! :D I started getting confused with Normally Open/Normally closed, etc. I thought I was sitting in an Aircraft Systems Class! So the bottom line is either relay will work but the RS one is cheaper obviously. What was the Part Number of the RS one you bought? I need to convert my Cub as well but I haven't really had to much trouble starting it. Glad it all went well for you.
Okay, busted. I am an engineer working for an aerospace company.
The part is identified as "12VDC/30A SPST Automotive Relay" part number 275-226, and lists at $6.79 The package just said "Auto Relay" and is a 12VDC relay rated at 30 amps, with a 7.8 VDC pull-in voltage and a 3.X drop-in voltage. Pics and diagrams are available through email upon request.
   / 7XXX Series Starter Problem - Again #13
Thanks Duke. I'll probably pick one up soon before I get to much snow here. I was afraid it would be a nightmare tracking down the wires and wripping apart the dash to get to the ignition switch. Have a good Turkey Day! BTW do you work for Boeing in Mesa?
   / 7XXX Series Starter Problem - Again #14
I'm a new member. I joined due to a starter problem and thru your questions and the solutions suggested I have now solved my problem. Very frustrating and glad to have a solution. So thanks
freespirit
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
Giyi 39" Mini 4-n-1 Bucket (A53316)
Giyi 39" Mini...
20' 18" Corrugated Pipe (A53316)
20' 18" Corrugated...
