7hp briggs
   / 7hp briggs #1
Lanse
Bronze Member
Ive been trying to get my mower working today, and it will run just fine on choke, but nothing elce. It also runs WAY faster then normal, and i cant seem to get the combination right on these screws on the carb, the idle and needle screw. What aint i doing???
   / 7hp briggs #2
I had the same problem and it turned out to be "Dirt" in the fuel bowl. I loosened the single hex "Nut" under the fuel bowl and cleaned everything with several blasts of Carb Cleaner and I've been good to go ever since.
Has it been running OK and then one day you went to use it and found you had trouble?
   / 7hp briggs #3
It could be a loose carb. The air could be sucking around the gasket and causing it to run lean, when you set the choke it makes the mixture richer and it runs "ok". If this is the situation, all the adjustments in the world won't change the way it runs because it's getting it's air from behind the carb.
   / 7hp briggs
it runs now, thanks yall
2009 Lee-Boy 8510HD Conveyer Feed paver (A53472)
2009 Lee-Boy...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
John Deere X530 (A51573)
John Deere X530...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
