790 Temerature Gauge
   / 790 Temerature Gauge #1
JDDan
The temperature gage on my 790 seems to only work intermittantly. Works better when it cold outside. On hot days it rarely works. Shop said to ground lead at sender. If it doesn't register max temp on gage, replace the gage. I checked it and it appears the gage needs to be replaced. The whole intrument cluster has to be replaced as one unit at a cost of $400. Has anyone come up with a better/cheaper fix for this.
Thanks
JDDan
   / 790 Temerature Gauge #2
Here is the page from the tech manual on the temperature sensor and guage. Although, I wonder about the sensor info accuracy in that the sensor is probably not on-off at a particular temperature but variable as temperature varies. You could remove the sensor and try the test. Also try the guage test.
  • Compact Utility Tractor 790-TM2088 Temp Guage.pdf
202482 (A54757)
202482 (A54757)
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
