sriddle1
- Joined
- Apr 2, 2014
- Messages
- 212
- Location
- SW New Hampshire
- Tractor
- ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
Gurgling sound?? I believe there have been some problems with the solenoid leaking??
Egon, Glad you mentioned that, leaking you say, is that fuel seeping up and around the shaft/plunger (I'm guessing) then perhaps causes the Solenoid to fail. When I pushed the plunger up 3/4 into the housing & before it hit the limit that's when I heard the gurgling. Perhaps another indication that the Stop Solenoid has failed, we'll see .......
Along that line of thought, I was wondering if I do put the tractor in the start position (after disconnecting the starter TBD??) the fuel pump will no-doubt energize and I suspect fuel will be spraying out of the hole :umbrella-guy: where the Solenoid's Plunger would normally sit in the stop position. Question, how much, perhaps I should place a couple of Scott's Shop Rages in that area + Dawn Protective Raingear..............
