790 Mid PTO Installation
   / 790 Mid PTO Installation #1
mountain_man
Rocky Mountains
JD790
I recently installed a Mid PTO option on my JD 790 (in preparation for a used snowblower) and thought this info would be helpful. The P/N for the Mid PTO (790) is BM17994 and cost $390. It took about 6 hours for the installation. Besides the kit, I also used 4 gals of Low Viscosity Hy-Gard transmission/hydraulic oil, and a new power steering filter.
Here's the PTO kit (started feeling like Tim "the tool man" Taylor) - "Sure are a lot of parts..."
Bottom of transmission with access plate removed. You also need a container to hold 4 gals of old transmission oil.
Mid PTO gearbox installed. (The easy part).
Wheel, fender, covers removed before PTO linkage installed.
Linkage installed. Note new PTO lever. With all the springs, levers, bellcranks, pushrods, Rube Goldberg would have been proud!
Note the tractor is being supported by a jack stand (close to the wheel hub) as well as the hydraulic jack (like having both a belt and suspenders).
More linkage to PTO gearbox. Parts fit easily however linkage adjustments take some time to get right with the dual stage clutch.
Cover installation. A PITA - trust me...
Final picture of cover from below. Tested PTO and safety lockouts.
   / 790 Mid PTO Installation #9
Nice to know. I didn't order the mid-PTO option and wondered if it was a mistake. Even though I doubt I will ever want the mid-PTO it is good to know it can be installed fairly easily and inexpensively.
Thanks for posting the good photos.
   / 790 Mid PTO Installation #10
Mountain_Man:
I'll have to chim in with Scott...I didn't get it mid-pto either but thanks for the info on install, the pic's are great felt as if I was under mine looking up.... /forums/images/graemlins/smirk.gif
Whiskey
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
2014 Lincoln MKZ (A55758)
2014 Lincoln MKZ...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2020 MAC TRI-AXLE FRAME TYPE END DUMP TRAILER (A56129)
2020 MAC TRI-AXLE...
City of Lakeland (A51691)
City of Lakeland...
