790 maintenance change
/ 790 maintenance change #1
neilw
Somervell County, Texas
John Deere 790
While surfing the Deere site I pulled up the on-line 790 Operators Manual to see if they had changed anything.
One item seemed to jump out at me.
The factory specification is now to change the transmission fluid, hydraulic filter and clean the suction screen after the initial 50 hours of operation. My 2001 manual did not call for the first change till 500 hours.
They also seem to have added turn signals to the tractor, redesigned the air filter ( got rid if the wing nut that seems to break so easily) and lowered the gross HP and PTO HP rating a smidgen. Wonder if they fixed the battery problem?
I know I know what would posses me to look at an on-line manual that I had already read a 100 times. Well when "Trading Spaces" is the only show on TV for hour after hour you too will turn to any diversion.
Excuse me I need to get outside and change my THF.
/ 790 maintenance change #2
Thanks for the heads up Neil. I'll probably wait 'til spring to change those fluids since my manual also recommends 500 hours. I wonder what prompted the change /w3tcompact/icons/smile.gif
Test
No change until 500 hours seemed excessive to me to start with. Considering most other manufactures call for a change much earler even with geared trannys.
/ 790 maintenance change #4
yes, I to confirmed this with JD on 2/11/03 the change was in manual OMLVU14371 ISSUE J2. I HAVE A 2002 MACHINE serial # confirmed it,but the dealer gave me a manual dated 1998 !!!!!!! My machine has only 60 hours on it. I, doing it tommarrow !!!!! <font color="red"> </font>
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
7'x12' Trailer (A64127)
7'x12' Trailer...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
