790 lift limit - hydraulic relief valve
   / 790 lift limit - hydraulic relief valve #1
jd790rf
Baton Rouge, La.
john deere 790
Just a quick question - If you try to lift something too heavy and exceed the 815 lbs lift on a 790, is there something that would divert the pressure and protect the tractor? I kind of thought there was a relief valve that would cut in; make a noise (at least on a Ford) and no damage would be done....it simply wouldn't lift the implement? Anyone know if there is a built-in safety guard of this type that saves the tractor itself by diverting the fluid around the load?
thanks for any replies.
   / 790 lift limit - hydraulic relief valve #2
I don't know of a tractor that 'doesn't' have a main system pressure relief valve.
On the 790, it's set at 2050 PSI
   / 790 lift limit - hydraulic relief valve #3
Yes, your tractor has a relief valve. There have been a few people who have raised the pressure so they can lift more. There are quite a few post's about the procedure from about 2 or 3 years ago.
Are you experiencing a problem that prompted you to ask the question?
Well,
I thought so when I tried to lift a King Kutter 2 5' tiller; but it was ultimately my dumb mistake. The tiller was raised up and down a couple times; I thought success!
It wasn't too heavy after-all. Then I tightened the valve to slow the drop on the pto equipment a little too tight and all of sudden the tiller wouldn't raise again. 15 minutes later after feelings of disaster and a strange sound when I tried to raise the tiller again; I realized what I might have done, opened the valve and the tiller would raise again. But then it just occured to me to ask and make sure there was a safety mechanism to keep tractor from being damaged by this type of thing in the future. Shipping said tiller was 690lbs but I never knew how much of that was packaging.
   / 790 lift limit - hydraulic relief valve #5
That stop valve block oil exhaust from the cyl.. etc.
happy tractoring.. your tractor should be fine..
soundguy
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
Used 20' Container Box (A52384)
Used 20' Container...
