Traction 790 John Deere Fuel and Temp Gauge problems
   / 790 John Deere Fuel and Temp Gauge problems #11
Confession first. I have owned my 990 since new. my 2000. And I have a very serious maintenance background. Just not enough time. Retired now. No more excuses.
For the last 15 years I thought the temp and fuel were sharing a common ground according to the wiring diagram. with intermittent problem. I started chasing it 3 days ago.
The gauges when NOT powered are below low fuel and low temp. I took the instrument cluster apart. Carefully. feel the needle travel and see if it is sticky where it would set with the key off. Mine was. a couple SMALL drops of trans fluid down the shaft where the needle is pressed on the gauge and then gently move the needle thru its travel loosened up and stopped sticking in the parked position. Fixed. :)
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2014 Ford Mustang Coupe (A55853)
2014 Ford Mustang...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
