790 how much will 70 loader pick up ?
/ 790 how much will 70 loader pick up ? #1
deerehoe
jd 770
hi I building crates to carry firewood I looking at half facecore to carry at one time. Wood weight is 600 to 800 pounds with pallet and forks I think Iwill be lifting 1000 any Ideas thanks Tim /forums/images/graemlins/confused.gif
/ 790 how much will 70 loader pick up ? #2
Hi Tim,
My old 70 loader could muster about 700 lbs in the bucket about 4 feet from the ground but not any more at that height. Don't forget the forks move the weight farther out and that lowers your lifting capacity.
Jim
/ 790 how much will 70 loader pick up ? #3
I doubt if you'll get that load 4' off the ground with the #70 loader. But you might get it a foot or two. Considering the weight, you might not want to lift the load more then a foot.
If you're using bucket forks (forks clamped to the bucket), that will really lower the weight capacity. I don't think I'd try anywhere near a 1000 lbs using bucket forks. If you're using the Deere forks (or equivalent) that replace the bucket...then I'd give it a try.
Make sure you increase your tire pressure to the maximum! There's a good chance a front tire could roll off the rim when making a turn. If that happened...at least is would be a real hassle, at worst it could roll your tractor.
Also, a thousand pounds is getting near the upper limits of the front axle capacity...something to think about.
What kind of rear ballast are you planning on using? I don't think filled tires would be adequate.
If you have a trailer you can hook to your draw bar, towing the load might be something to consider. The only difference I see is you'd have to stack your wood after the move.
/ 790 how much will 70 loader pick up ? #4
If you just need to move the loaded crates around, why not pick up a set of 3PH forks and carry the load off the back of the tractor?
/ 790 how much will 70 loader pick up ? #5
The three-point forks sound like a good idea. They won't be as handy, but should accomplish the task.
2006 TerraGator 8104 (A63688)
2006 TerraGator...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
SHORTWOOD LOG TRAILER (A64276)
SHORTWOOD LOG...
2021 International HX620 Quint Dump (A62613)
2021 International...
