3-Point Hitch 790 3 point sway adjusters
   / 790 3 point sway adjusters #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
The sway adjusters on my 3 point hitch used to work great. But now it seems I cannot tighten them the same as I did in the past. I have the roll pins turned as tight as possible and get excessive swaying with my implements now. Did I somehow stretch the hardware??? :confused: Everything looks the same. I have had some pretty heavy loads back there (disc and cutter and box blade work) but didnt think I could stretch the hardware. :confused: Anyone else experience this with a 790 or similar set up ?
   / 790 3 point sway adjusters #2
Yesterday I noticed the same thing happening on my 790. We have been doing a lot of brush cutting this year. While hooking the tractor up to the box blade I noticed the extra sway of the lift arms but did not think to much about it. Will have to take a closer look at it when I have time.
   / 790 3 point sway adjusters #3
Your draft arms are bent - you need to remove them and hammer them back with a sledge hammer....this will take up the slack...
I looked at my 3 point hitch parts again.....it's all in tact and looks like it's right......but I think an earlier episode I had caused some damage.......and I beleive your right Flywheel. Thanks for confirming the problem. Early this spring I did loose some of my linkage due to pins coming out in the brush....and I think this resulted in bending a lower pin.....maybe other stuff.
I think it's going to have to wait till fall/winter....cause I got too much to do right now. But I think I will take it all apart and put the fix on the bad parts.
Thanks.
2003 Big Tex 10PI...
2016 Ford Expedition SUV (A55853)
2016 Ford...
2015 Cadillac Escalade ESV SUV (A55853)
2015 Cadillac...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
