7800 Top and Tilt
   / 7800 Top and Tilt #1
furb59
I am about to purchase my 1st tractor. I have decided on a Kubota B7800HST. I will be using the tractor during the construction of our house. Weed abatement, finish grading, fence installation, and landscaping. After const. it will be used to maintain the property and horses. Do I need to purchase the Top and Tilt hydraulics from the dealer? If so, how much should it cost?
   / 7800 Top and Tilt #2
You can do it through the dealer or you can do it yourself. Rather than everyone speculating, why not just get a quote from the dealer and go from there? By the way, have you considered the fact that you are purchasing a tractor without position control on the three point? If you intend to do enough landscaping where top and tilt is necessary, you really should consider position control as mandatory as well.
   / 7800 Top and Tilt #3
I like the clean looks of the factory valves. Many people do grading with the 7800 3pt hitch lift system with no problems, some can't seem to make it work for them. I've used the system on the 7800 the least but have had great results with it and found it to give me better control then with position control. Thats after over forty years with the position control!
   / 7800 Top and Tilt
What exactly is position control?
   / 7800 Top and Tilt #5
for finish grading top and tilt and position control sure would be nice. You can do it without them, but won't like the process I'm guessing.
I wish I had bought mine with top and tilt, and will be putting it on.
For mowing type stuff it's obviously much less necessary.
   / 7800 Top and Tilt #6
Position control is a system that allows you to set your implement (like a box blade or back blade) in exactly the same position (height) every time you drop it. It can then be raised or lowered in exactly the increment you ask it to by moving the lever a little or a lot. When the hitch gets to the position you have asked it to, it stops there until you apply another input at the lever. A quarter inch valve (like on the 7800) is either full up or full down, until you stop it by going the other way, with one exception. You can alter the height a quarter inch at a time. I have used both, and like the vast majority, find PC to be a far superior system. With a quarter inch system, there is no way to set the implement at the same height every time. Think about spreading loam to a desired thickness and which would do the job better. I use it with my rear snowblower to blow a portion of my lawn where I park my snowmobile trailer. I set the height, never dig up the lawn. You get the idea.
A three point with position control and top'n'tilt with check valved cylinders is a great tool. I love mine.
   / 7800 Top and Tilt
8561...Thank you. Very good explanation. I understand.
   / 7800 Top and Tilt #8
If your tractor has not been delivered yet, I'd work the TnT and remotes into the deal. Does not cost your dealer much to get these done while he is setting up the tractor anyway and I think that he'd be happy to work out a deal that is worthwhile for you to get the tractor configured exactly as you want it from day 1.
I would also recommend that you get an extra spool - for something else that WILL pop up in the future. Get three spools - one top, one tilt, one spare.
Honestly for the B series and the standard L series, there is not much difference in how clean the "factory" setup is vs. an after market setup. I've just installed an aftermarket setup on mine. The factory setup does not have hard lines and just bolts on to the ROPS like you would an aftermarket setup. That said - might as well get the dealer to do it for you so you can start playing from the start!
   / 7800 Top and Tilt #9
Since you didn't tell us how much the dealer wants for it, it's hard for us to say which way to go. But I can tell you that, in 1999, the two dealers I talked to said Kubota did not have a top 'n tilt for the B series (I had a new B2710) so I did not own without really knowing what I was doing, but with a lot of help from Tractorbynet members and I spent a little over $800. One dealer had told me they had one for the L series for $1,400.00. Terribly expensive, but well worth it, in my opinion.
   / 7800 Top and Tilt #10
another thing - if you are doing a lot of ground work a heavier L would be a better bet. Certainly weigh the tractor down as much as possible through filled tires, weights etc in any case. Weight = traction generally
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
1269 (A50490)
1269 (A50490)
