7740 sle transmission
   / 7740 sle transmission #1
thomashawke
we have ford/newholland 95 7740 sle 7500hrs up.it started to grind getting it into reverse, so i had a look a found that the lock nut was loose on adjuster top of transmission.adjusted it, to where it stop grinding (lovely), but it started to grind going into forward after a few times of normal operation! is this a problem with adjustment or faulty solenoids , there known to give trouble so i have been told,had to rewire earths ,a lot were bad connection and broken.any information would be greatfully apprieciated.
thanks
have no manuals or experience in this field !
:rolleyes:
   / 7740 sle transmission #2
No solenoids or earth connections involved here. You should try to fine tune the cable adjustment, but that may not be possible. Your Forward/Reverse synchronizer may be trashed. It requires a double split (transmission removal) to replace. The snchronizer was over $2000USD several years ago. The 1-4/5-8 synchronizer should be examined carefully, as it will be next to go. It would also be prudent to replace the piston seals and sealing rings in all 4 clutchpacks with those hours, given the transmission will be mostly disassembled. Just remembered there is a serial number break on that synchronizer, be careful when pricing/ordering parts.
   / 7740 sle transmission #3
looking for someone knowlegeable about these tractors have spent over 3000 usa dollars and still not working
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2016 FONTAINE 53FT SPREAD AXLE DROP DECK FLATBED TRAILER (A53426)
2016 FONTAINE 53FT...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
