7740 ford
   / 7740 ford #1
dustinkempfly
christchurch
ford John deer messy
Hi guys I've got a 7740 ford the pto kicks out after 20 minutes once it's at about 80 degrees operating temperature. Then it kicks back in slowly and eventually builds up speed again I've buy passed the electrics to rule that out. Put power straight to solinoid on pto still does the same thing. Could it be the solinoid in the pto breaking down or could it be a hydraulic issue. Once it kicks out it kicks out quicker and quicker
   / 7740 ford #2
Reads like a failing solenoid coil. Take accurate resistance readings from the coil feed wire to ground both cold then hot when causing trouble. If the resistance changes significantly, you have the answer.
   / 7740 ford
Would it be worth stripping clutch pack and checking the plates
Frontier RC2060 (A56469)
Frontier RC2060...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2025 Mower King SSCM53 (A56469)
2025 Mower King...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
PT Gravity Flow Wagon (A56469)
PT Gravity Flow...
