7710 ford
   / 7710 ford #1
ken1960
2006 mccormick
i need some help , gt 7710 cab tractor i am geting hyd. fliuld in the bell housing area i put selioniond on that makes dual power work an i ck the vale an it is not leaking what else is there in there that can be leaking i know it supose to be dry in there. it will leak 3 or 4 gallon in there real quick can anyone tell me whats going on .
   / 7710 ford #2
you better take the tractor to the shop.that is a big prob that your dealing with.
   / 7710 ford #3
Sound a like a rear seal separating the clutch housing with the tranny, which is connected to the rear axle witch is full of oil, should be able to get to it by splitting the tractor, then taking the dual power drive out
Edit* just had a read of your other posts if your dual power is not working, sound like your problem might be there, the two are probably linked
   / 7710 ford #4
Agreed with Andrewnewy, we split our 7710 last year all the way, pulled cab, what a job, but worth it, deffinately sounds like rear seals to me. Unfortunately that means pulling cab, linkage, ptetty much everything to access it. Might as well check those cultch packs as long as your going in that deep. After having a ford disassembly line in our shop for a month or
More last year I'd say take it to a ford/nh mechanic, it's a big
Job. Seals are easy enough though... Once your in there. ;-)
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
2017 International Distributor Truck (A52377)
2017 International...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
