Loader 770 Kickstands
   / 770 Kickstands #1
kc5sii
Oklahoma
Ford 1310, '72 Cub 1410, Swisher 66" ZTR -w- 60" Trail Mower.
I discovered what the two l shaped pieces of metal stored around the front of the tractor are for. I understand they are the kickstand for removing the loader. However, for the life of me I can't figure out how they would support the loader when disconnected from the tractor. Does anyone know?
   / 770 Kickstands #2
There are several different types depending on the loader design. They usually are described in the loader operating manual.
   / 770 Kickstands #3
The stands, #24 fit into the hole that pin #22 was in
After loosening the clamp setup and removing pin #22, the stands fit into the pins hole after lifting the loader frame up.
   / 770 Kickstands
Thanks for the reply. From the drawing it appears that pin 22 is a bolt. Will the round part of the stand slide into that hole or the larger hole that appears to anchor the end of the lift ram? (Part # 21)
Also, what keeps the stand from flopping over? Does soemthing go into the hole?
   / 770 Kickstands #5
my bad..pin 22 in the second diagram. The pin that holds the frame to the mount on the transmission. I would suggest getting an owners manual before attempting removing the loader. It's heavy and not fun if it falls over, also a good way to get injured.
   / 770 Kickstands
Okay, I see and there is a small piece of metal welded to the loader frame that keeps the pinned stands from "Flopping" forward or backward. Right?
I guess it woudl be prudent to put a block of wood inder the stands. Otherwise they would sink into the gorund.
   / 770 Kickstands #7
Definitely put a block under the stands.
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2015 GENIE S-60 MANLIFT (A58214)
2015 GENIE S-60...
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
