7610 BackHoe questions
/ 7610 BackHoe questions #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I am attempting to learn which backhoes (with a subframe mount) wil fit my 7610. I would like a Kubota but if there are others out there as good in quality and have a subframe they would fine with me. Also what kind of price (setup on the tractor) should I expect to pay for each make? My budget is limited but it looks like I maybe able to swing it (no pun intended) next month. I am located in Southern WV.
Thanks!!!
/ 7610 BackHoe questions #2
Woods makes at least one BH for the B series that I am pretty sure has a subframe. Well thought of BH company and reasonable alternative to the Kubota product.
/ 7610 BackHoe questions #3
The Kubota B4672A back hoe with sub frame #B4681 will fit. MSRP is $6600.00 plus bucket. You will have to change your ROPS also. Hope this helps.
Lewis
/ 7610 BackHoe questions #4
I am also looking for a back hoe for a B7610. I have a one year old model with a folding ROPS. What is the interference with the ROPS?
/ 7610 BackHoe questions #5
The folding ROPS is ok, it is the rigid one that needs to be changed. Interference with the operator's head is probably the reason for the change.
Lewis
Thanks!
What do you feel is a FAIR price for the BH installed? Are the other "makes" cheaper and of the same quality?
/ 7610 BackHoe questions #7
Bradco make a subframe Bh that is a decent hoe. I used one on a B7500 for over two years and never broke it digging stumps and other stuff.
It was not as powerful as the Bh75 I have now and the seat was cheap vinyl but it was a smaller tractor and hoe.
I would recommend one that does have a two cylinder swing system because it is more powerful than a single cylinder and back filling a hole is easier.
Is there anyhting special I need to look for before buying a backhoe other than a sub frame mount? Are they all pretty much the same if you go with a major company?
/ 7610 BackHoe questions #9
There are differences between the major brands but I think it is fair to say they will all do the job and are reliable.
Today my one local dealer gave me a price of $6800 for the hoe, 16" bucket and install W/subframe for the Kubota hoe. Is this reasonable? Also is the 16" bucket the "normal" bucket or is there a reason to go with a 12" for general use?
/ 7610 BackHoe questions #11
I'm late responding to this one, but I think the upper $6000.00 to $7000.00 will be the range installed, depending on PTO pump or tractor hydraulics, subframe and bucket choice. Kubota, Bradco and Woods are good units.
Lewis
Thanks!!! Is there a big price difference between the Kubota and other makes?
/ 7610 BackHoe questions #13
The Kubota B4672A Backhoe is a 3 Point hitch mounted backhoe. The subframe that is used is 2 extra frame supports that go around the axle housings up to the engine frame.
It is a good bit of labor to install, but does make the frame alot stronger. The larger B's like the B7800 B2710 and B2910 all have this framing from the factory. The B3030 B2630 are different because the backhoe is different
FORD 4500 TRACTOR (A64280)
FORD 4500 TRACTOR...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
Unverferth 330 (A64119)
Unverferth 330...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
(1) 8 LUG TRAILER STRAIGHT AXLE (A64280)
(1) 8 LUG TRAILER...
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
