Oil & Fuel 76 B7100 Fule injector pump
   / 76 B7100 Fule injector pump #1
carmichaelb
Alaska
Kubota B7100
Anyone familiar with the shims to set the fuel timing on an old B7100? I rebuilt the engine but am not getting the power I expected. The only thing I was unsure of in the rebuild was the shimming of the fuel pump. Any suggestions?
   / 76 B7100 Fule injector pump #2
Unless you replaced the block, cam or crank, the shimming will be the same..
The problem probably lays in the fueling set up.. The max fuel can be adjusted along w/ the engine rpms..
Do you have any smoke at wide open..
Is the throttle lever touching the stop screws?? are you using a hand held tach for rpms or relying on the dash guage?
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
Hercules Gun Safe (A55853)
Hercules Gun Safe...
2 BOTTOM PLOW (A57192)
2016 JOHN DEERE 323E SKID STEER (A52707)
2016 JOHN DEERE...
2022 Padget Morris Electric Mobility Scooter (A55853)
2022 Padget Morris...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
