Oil & Fuel 76 B7100 Fule injector pump
   / 76 B7100 Fule injector pump #1
carmichaelb
Alaska
Kubota B7100
Anyone familiar with the shims to set the fuel timing on an old B7100? I rebuilt the engine but am not getting the power I expected. The only thing I was unsure of in the rebuild was the shimming of the fuel pump. Any suggestions?
   / 76 B7100 Fule injector pump #2
Unless you replaced the block, cam or crank, the shimming will be the same..
The problem probably lays in the fueling set up.. The max fuel can be adjusted along w/ the engine rpms..
Do you have any smoke at wide open..
Is the throttle lever touching the stop screws?? are you using a hand held tach for rpms or relying on the dash guage?
Progressive 36ft Mower (A52128)
Progressive 36ft...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
