Backhoe 757c vs 757b
/ 757c vs 757b #1
grl1961grl
Bath NY
Kubota B20 TLB & new hollandtc30
i was wondering if someone could tell me the difference. My 1520 Ford spec says 757B , but i have a chance to get a 757C. thanks for any info you could give me. it comes with the sub frame , although its off a 2120. i should beable to mod it to work .I dont have rear remotes, so ill be searching on here for a way to get the hyd hooked up too. i thought of buying a pump and hyd tank, if i can find one, and make it self contained, any thoughts on that would be welcome also
/ 757c vs 757b #2
Other than the B being made by Ameriquip (Arps) and the C being made by Schwartz (SML), you have similar backhoes.
If you can modify the frame to fit, then you can get the hydraulics hooked up easily. Take a look at the photo.
/ 757c vs 757b
Thank you for the info, and drawing, my hoe should be here this week, and i can finally got going on the install
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
Adams 5T HC (A63688)
Caterpillar 3208 Power Unit (A64127)
Caterpillar 3208...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
