757c BH ????
   / 757c BH ???? #1
treefarmer391
Looking for a bit of help here guys. My BH boom started dropping if left sitting for a week. Can use the boom lock to keep it up, but was wondering if anyone else out there has the problem? Checked the UTF fluid, and it seems OK, but there are many different levels mentioned. Whats correct? Anyone out there with the repair manuals? Is there anything on adjustments for this?
Thanx in Advance.....
Brad
CT.
   / 757c BH ???? #2
Mine is only a year old and it drops a little over night if I forget to clamp it. I have had no trouble from it. I think it may be normal. I normally stretch it out where the shafts are concealed inside the housings when I park it for a while. If at a remote location on a job I put the safety clamp on it. No one should fool with it, but kids will be kids and I nevery leave my hydraulics up where they can fall if the levers are pressed.
   / 757c BH ???? #3
It's supposed to do that. The way it was explained by the dealer to me is one of the relief valves is designed to let a small amount of flow all the time, the purpose is to prevent shock loads when moving the tractor caused by the boom bouncing around. My 758c was dropping so fast I could see it and the valve had to be replaced, which solved the problem, but it still will drop over time. I second the motion to lock the boom or set it down when parking, safer and easier on the sysem.
   / 757c BH ???? #4
It is normal..
There is nothing wrong with your backhoe.
   / 757c BH ???? #5
That's exactly the reason for the lock. Mine has dropped since new.
   / 757c BH ???? #6
Brad
CT.
Mine does the same thing, and the satbilizers are leaking down too, the bucket uncurls a little... I use the lock for the boom... I wish there were locks for the stabilizers there too..
   / 757c BH ???? #7
I noticed the 758 has locks for the stabalizers, just like the lock for the arm. Has anyone tried adding the locks to the stabalizers?
See attached picture of a 758 BH.
I was thinking I could buy the locking plate and have someone weld on the stubs...
   / 757c BH ???? #8
On another post about the dropping boom, someone said they use a ratchet strap between the two.
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
FRONTIER WR3212 LOT NUMBER 57 (A53084)
FRONTIER WR3212...
